v10 spk1 - Users claim ECHO during external calls
Discussion in '3CX Phone System - General' started by jr3151006, Jul 20, 2011.
  1. jr3151006
    jr3151006 New Member
    Jul 30, 2010
    155
    we have v10spk1 running on XP spk3 and some Cisco phone (SPA 502g and 504g - using P.O.E switch) and 'SOME' users are claiming regarding echo during external calls (outbound/inbound via sip trunk or via gateway - SPA400).
    How can I debug this issue? It would be related with network latency? Codec used in the phones?
    * I´m monitoring right now through SNMP my ADSL modem connection, 3cx server and so on.
  2. KerryG
    KerryG Active Member
    Jun 19, 2009
    960
    Could be that you just need to turn the microphone gain on the phone down.
  3. willow
    willow Member
    Mar 1, 2011
    471
    echo is normally an impendence issue between two wired deviced. I would try Kerry's idea first, alot of echo has been fixed by simply turning the volume down or turning off automatic gain control for the handset.
  4. KerryG
    Jun 19, 2009
    960
    I would agree but if 'some' users are complaining of echo with these particular phones, I am leaning towards it being an acoustic echo via feedback in the handset and not an impedance issue since it is not affecting everyone.
  5. jr3151006
    Jul 30, 2010
    155
    I cannot found an option to enable/disable the Gain for the headset but I found the information bellow. To me it seems that the 'gain' is disabled to all options. It´s Correct?
  6. KerryG
    Jun 19, 2009
    960
    Try
    Handset Input Gain: -2
    Try to find a balance where the echo stops but the volume to the other person isn't too low.
  7. jr3151006
    Jul 30, 2010
    155
    Ok Kerry,
    I´ll try and monitor.
    tks a lot!!
  8. netswork
    netswork Active Member
    Mar 11, 2011
    577
    Where did you find to adjust the gain? I dont see anything in the phone provisioning files for gain.
