v10 spk2 - 3CX Log Reporter -Custom Logo and Footer no saved
Discussion in '3CX Phone System - General' started by jr3151006, Jul 25, 2011.
  1. jr3151006
    jr3151006 New Member
    Jul 30, 2010
    155
    every time that I try to generate a report, must I configure the custom logo file and Footer???? Is there a way to save that customization???
  2. willow
    willow Member
    Mar 1, 2011
    471
    Re: v10 spk2 - 3CX Log Reporter -Custom Logo and Footer no s
    I just tested my v10 and it appears to save the customer parameters.
  3. JFlagler
    May 24, 2011
    I can't seem to get this to work either. Is there something I need to click for it to save the settings?
    3cx v10 with all updates is running on Windows 7 Pro 32 bit. I'm logged in as the administrator.
    Does anyone know where the file is located that is supposed to store the custom settings? I suspect a permissions issue, but on the other hand I'm logged in as the admin.
    On top of that it uses a strange custom page size every time so I have to manually intervene and tell the printer yes go ahead and print.
