v10 spk2 - Call Reporter - change the 'Cost'
Discussion in '3CX Phone System - General' started by jr3151006, Aug 22, 2011.
  1. jr3151006
    jr3151006 New Member
    Jul 30, 2010
    155
    Where can I change the 'cost' values that appears that report?
  2. nbailey
    nbailey Member
    Jan 31, 2011
    359
    Hey,
    From the management console go to the top left menu bar. Select View > Billing options.
    Thanks,
    Nate
