v10 spk4 - DR menu - statistics of usage
Discussion in '3CX Phone System - General' started by jr3151006, Dec 21, 2011.
  1. jr3151006
    jr3151006 New Member
    Jul 30, 2010
    155
    we have 2 DR (Digital Receptionist), one for 'PT-BR' and another to 'ENG' language used to receive external calls; some times we change the options (extensions and so on).
    >>>>>>>>>> There is a way to diagnostic what is the option most used in each DR???
    Something like:
    - You received 12 calls;
    - 5 used the option '0';
    - 2 dropped;
    - 3 used the option '1';
    - 2 used the option '9';
