v10 spk6 - firewall checker question regarding 5060 UDP
Discussion in '3CX Phone System - General' started by jr3151006, Apr 10, 2012.
  1. jr3151006
    jr3151006 New Member
    Jul 30, 2010
    155
    since to run the 'Firewall Checker' we should to stop the services 'siptrunk' and 'phonesystem', what service will listen for 5060 port????
    After stop this service to run the 'Firewall Checker' I´m not able to run a 'netstat -a' to check if this port is listening, also the results shows the following:
    Does anyone idea on how to trouble this issue??
  2. craigreilly
    craigreilly Well-Known Member
    Feb 1, 2012
    3,575
    304
    Same here. Very annoying buy my system seems to be functioning ok.
  3. jr3151006
    Jul 30, 2010
    155
    Can 3CX team to update the 'firewall checker' utility to inform what address:port it is trying to check??
    * To me it´s not clear if it is trying to connect to internal IP address (192.168.1.244/24) or external address (201.22.xx.yy).
