v10 spk6 - sip trunk not connecting
Discussion in '3CX Phone System - General' started by jr3151006, Apr 5, 2012.
  1. jr3151006
    jr3151006 New Member
    Jul 30, 2010
    155
    can anyone help to 'translate' this msg?? What is means??
    Code:
    15:13:44.140  [CM504005]: Registration failed for: 10001@GVTFaleVono; Cause: 400 Bad Request; warning: Noisy feedback tells:  pid=15180 req_src_ip=10.141.1.112 req_src_port=5060 in_uri=sip:vono.net.br:5060 out_uri=sip:vono.net.br:5060 via_cnt==2; from IP:201.86.87.36:1571
    tks,
    Renato P
  2. Aboxtech
    Mar 19, 2012
    15
    This typically shows up when you have an older firewall that is doing "fixups" to the SIP protocol. Try turning it off and the problem should go away.
  3. SY
    SY Well-Known Member
    3CX Support
    Jan 26, 2007
    1,825
    Time to ask Voip provider for feed back and then check equipment which is serving connection between PBX and provider.
  4. jr3151006
    Jul 30, 2010
    155
    According to this post we should to adjust the 'caller id' info. Can anyone help us?
    https://supportforums.cisco.com/thread/274430
  5. jr3151006
    Jul 30, 2010
    155
