v10 VOIP Providor (Virtual Extension Number)
Discussion in '3CX Phone System - General' started by chrisneal, Jun 20, 2011.
  1. chrisneal
    Nov 20, 2008
    27
    When adding a Generic VOIP providor.. A random Virtual Extension number is generated. When I try and change the Virtual Extension Number it complains that it's not a valid Virtual Extension Number... I think it's reading the ENL for Regular Extensions and trying to apply the rule to VOIP providors.
  2. davidbenwell
    davidbenwell Active Member
    Apr 27, 2010
    704
    Why would you need to change the virtual extension number?
  3. chrisneal
    Nov 20, 2008
    27
    By Default it's creating 6 Digit Virtual Extension.. And it works.. However, we can't change the authentication information because it then says the Virtual Extension is Invalid. It's forcing me to change the Virtual Extension to a 5 Digit number which matchs the ENL. In v9 it Gateways Virtual Extensions did not have the be the same length as regular extensions.
