v10 - warning missing about password length!!**DISCUSSION
Discussion in '3CX Phone System - General' started by jr3151006, Apr 27, 2011.
  1. jr3151006
    jr3151006 New Member
    Jul 30, 2010
    155
    I cannot see any warning regarding the pwd lenght for the extensions! But I found on the web interface that extensions shows in red color!
    >>>> Hey DEV Team, can you create a warning when create an extension for that issue?????
    tks,
    Renato P.
  2. nb
    nb Support Team
    Jun 7, 2007
    2,129
    152
    Re: v10 - warning missing about password length!!
    What warning would you like to see and when?
    It shows red because you have something that is insecure
    Either Auth id and Vmail pins that are the same as the extension or a sip id that is the same as the extension.
  3. smb1
    smb1 New Member
    Mar 18, 2009
    104
    Re: v10 - warning missing about password length!!**DISCUSSIO
    A warning could be displayed when clicking OK/Apply when editing the password/pin for an extension as a pop-up and ask for confirmation prior to accepting the insecure credentials.
  4. jr3151006
    Jul 30, 2010
    155
    I agree with Dave Bennet, other option could be show a pop-up warning when you put your mouse pointer over the field in `red`...
    Renato P
  5. matictec
    matictec New Member
    Mar 31, 2008
    188
    Or if you enter a password, a small indicator can show the password strength, while typing. some websites use such an indicator.
  6. nb
    nb Support Team
    Jun 7, 2007
    2,129
    152
    Showing the extension in red is an indicator already. we think that this is enough. Plus we show you the fields that are problematic and risky. Keep in mind that the management console is for admins. A level of attention is expected.
