V11 and SQL
Discussion in '3CX Phone System - General' started by haywardi, Mar 18, 2013.
  1. haywardi
    Feb 27, 2011
    83
    I'm currently running V10 without any problems but thought it was about time I upgraded to V11.
    My usual practice is to load a new version on a test server, do some testing and if everything OK load onto the live server.
    Initial testing of V11 is fine, but I noticed a warning appear during the installation saying something about do not load onto the same machine as SQL server.
    Suffice to say that my live server runs SQL server as well.
    Can anyone advise is it just a performance issue or is there a conflict somewhere?
    Thanks in advance
    Iain
  2. kevin
    kevin Member
    Nov 23, 2006
    316
    @Iain
    Mainly about performance issues, and also because we do not perform any in-house testing for such a combination. 3CX Phone System will install its own database engine (PostgreSQL), and having 2 database engines competing for resources is almost never a good idea.
  3. haywardi
    Feb 27, 2011
    83
    Hi Kevin,
    Thanks for the insight.
    Do you know if this has changed with v11?
    I ask as I have v10 and sql-server 2008 residing on the same server at the moment without any problems and would like to continue with this setup if possible.
    Iain
  4. kevin
    kevin Member
    Nov 23, 2006
    316
    @haywardi
    V11 and V10 both use PostgreSQL as their back end database, so in that respect they are the same.
  5. haywardi
    Feb 27, 2011
    83
    Hi Kevin,
    Thanks for the info as it means I can safely run V11 and SQL-server together :) phewwww.
    Can't vouch that this setup will work for anyone else, but V10 has been run for circa a year and never had a problem or conflict. In fact V10 has been a case of set and forget....
    Iain
