v11 DID's
Discussion in '3CX Phone System - General' started by craigreilly, Sep 27, 2013.
  1. craigreilly
    craigreilly Well-Known Member
    Feb 1, 2012
    3,586
    309
    In v11, when someone in my network dials 1 of our DID's, it goes out and comes back in. Is the only way around this to create a VoIP Provider with a Loopback to 127.0.0.1?
  2. ian.watts
    ian.watts Active Member
    Apr 8, 2011
    532
    None that I saw. I didn't take it that far and just had the outbound rule for the DIDs block instead, but I'm mean. ;)
  3. craigreilly
    Feb 1, 2012
    3,586
    309
    i like that better. teach them the right way - instead of just fixing it for them... :)
