V11 email notification
Discussion in '3CX Phone System - General' started by mixig, Sep 4, 2012.
  1. mixig
    mixig Active Member
    Dec 13, 2011
    530
    12
    i noticed that email notification on v11 are not working for me, i have several 3cx and they all have the same ISP and they all are using same smtp server from that ISP. On version 10 notifications are working, on v11 they dont. I also tried with bmail program (cmd prompt program which is capable send emails) from the server where 3cx is install and with the same setup just to test mail server of my provider and i got an email. What I can see in wireshark is that i dont get any traffic from 3cx (mail traffic), I also tried to put ip addresses of mail server instead of FQDM and nothing.
    Is there any logs for emails in 3cx files? Maybe I can find somthing in the logs...
    11,116
    329
    Are you using a licenced or free version?
  3. mixig
    mixig Active Member
    Dec 13, 2011
    530
    12
    All of them are licenced, if there are some logs for emails i can check...
