v11 export
Discussion in '3CX Phone System - General' started by smtharrison, Sep 7, 2017.
  1. smtharrison
    Mar 13, 2012
    17
    Hey folks, anyone know if there's a way to export extensions from v11? Moving a few installs to a corp install in my DC to consolidate. Changing from 3-4 digit extensions, so figured an export would be the easiest way to do this. Thank for any tips!
  2. sip.bg
    sip.bg Active Member
    Nov 7, 2016
    704
    220
    You can backup the configuration and edit the .xml file. Good luck. Other option is to recreate the PBX from scratch, if it is not so big.
