V11 issue ??
Discussion in '3CX Phone System - General' started by donbru01, May 25, 2012.
  1. donbru01
    donbru01 New Member
    Nov 30, 2011
    134
    Hi , i have try to manage re-format caller-id 3CXPhone system . Gateway is Patton 4120
    Before using feature re-format caller id , phone ring using RingTone external correctly
    After using feature re-format caller id , phone ring using RingTone internal
    It is correct ? or it is issue ??
    Bruno
