(v11) Myphone not showing 24 Hours
Discussion in '3CX Phone System - General' started by oedlan, May 14, 2012.
  1. oedlan
    Nov 3, 2008
    18
  2. mixig
    mixig Active Member
    Dec 13, 2011
    530
    12
    By default my MyPhone is synchronized with my computer..., if I change time on my computer, immediately that change is applied to MyPhone...
  3. oedlan
    Nov 3, 2008
    18
    IIRC, this was the problem last time too.
    MyPhone is installed on a Terminal Server, and had to be manually patched by a 3CX tech.
    On my local computer it works just fine.
  4. oedlan
    Nov 3, 2008
    18
    Even though it's still Beta, I just posted a ticket for this issue since noone has answered me here 8)
