V11 Presece over bridge "blocked"
Discussion in '3CX Phone System - General' started by acolville, Jun 18, 2012.
  1. acolville
    Jul 27, 2009
    80
    I am testing V11 with three sites each linked via a VPN and Direct bridge. The presence between two of the sites works perfectly (Well done 3CX!).
    But I am having some problems connecting the third site as follows:
    Site C does not appear in myphone as a new tab in sites A,B.
    Sites A,B do appear in myphone at Site C, but when the tab is clicked (either A or B) a message is display which states:
    The connection has been rejected by the server (ip add) because the administrator blocked remote connections.
    How do I unblock remote connections for the bridges?
  2. acolville
    Jul 27, 2009
    80
    SOLVED: V11 Presence over bridge "blocked"
    Found the issue. I had only enbabled the "publish" to/from on PBX C's end of the bridge and not on Server A and B. Now that that is done everything is up and running.
    Now for some testing!
