v11 Service pack 3
Discussion in '3CX Phone System - General' started by mixig, Dec 17, 2012.
  1. mixig
    mixig Active Member
    Dec 13, 2011
    530
    12
    it seems that service pack 3 came... no offical announcement yet...
  2. complex1
    complex1 Active Member
    Jan 25, 2010
    815
    49
    For the moment not here.... :(
  3. craigreilly
    craigreilly Well-Known Member
    Feb 1, 2012
    3,575
    305
    Where did you see SP3 is released?
  4. mixig
    mixig Active Member
    Dec 13, 2011
    530
    12
    This morning it was there (i connected to the customers 3cx), now there is no sp3... wired...
  5. craigreilly
    Feb 1, 2012
    3,575
    305
    maybe they found a problem with the package and pulled it.
  6. mixig
    mixig Active Member
    Dec 13, 2011
    530
    12
    It`s there (deja vu)
  7. netswork
    netswork Active Member
    Mar 11, 2011
    577
    http://www.3cx.com/blog/releases/3cx-phone-system-v11-service-pack-3/
  8. craigreilly
    Feb 1, 2012
    3,575
    305
    Its telling me it cannot download - the directory is not empty. What directory?
    So I click again - and voila - it starts the update.
    Very intuitive... :)
  9. netswork
    Mar 11, 2011
    577
    Gosh Craig, you forgot to empty your directory first. Ha.
    I havent tried upgrading yet so I am going to let you be the ginny pig.
  10. craigreilly
    Feb 1, 2012
    3,575
    305
    I have only done it on my test system and it survived. So, when I get some time to stay late - I will do the upgrade. The problem is people like to work like 2 or 3 hours past closing... and I get grief if I tell them phone system will be down for 15 or 30 minutes for update. The "stay laters" are often dealing with their international clients at this time.
  11. eagle2
    eagle2 Well-Known Member
    Apr 27, 2011
    1,085
    11
    The actual upgrade is one or two minutes only, after downloading SP3, not 15 or 30 minutes.
    It will be nice if you could schedule it later or when system is idle.
    Regards
  12. netswork
    Mar 11, 2011
    577
    I upgraded mine with no issues so far.
  13. mixig
    mixig Active Member
    Dec 13, 2011
    530
    12
    Me too...
  14. vectra
    Nov 3, 2009
    28
    I got choppy audio after sp3 installation. Sangoma PRI card on cbeyond. Local calls are ok. Outgoign audio ok but incomeing very choppy. Any ideas?
  15. left
    Sep 14, 2012
    16
    My customized Wallboard - yet again - reverted back to the original one. Good thing I made a backup!
    Adam
    LeftClickHere.com
