v11mt and v12mt on the same server ?
Discussion in '3CX Phone System - General' started by egiblockDM, Jul 10, 2013.
  1. egiblockDM
    Apr 22, 2013
    39
    we'd like to start testing v12. is it possible to install v12 muti-tennant onto the same server where v11 multi-tennant is already installed? or is it best to just install it onto a separate server?
    thank you.
    10,362
    226
    You are probably asking for problems if you "combine" the two. There could be issues with shared directories, or port conflicts, depending on exactly how the installation/set-up is done. Given that V12 is still in Beta, I would want to run it on a completely independent piece of hardware, you don't want to risk affecting a working system. You will then be sure that any issues that do arise (and at this point, there will do doubt be a few) are not caused by a conflict with the other version. Version 12 Beta may have to be completely removed and be re-installed once it it ready for final release.
    Just my opinion, other may see things differently.
