V11SP4 no incoming calls after win 8.1 update
Discussion in '3CX Phone System - General' started by KenC, Dec 4, 2013.
  1. KenC
    Mar 29, 2012
    85
    I followed the windows update recommendation and installed 8.1. My 3cx v11sp4 wouldn't accept incoming calls. I tried to reinstall 3cx but when attempting to open the administrative interface got the exception "configuration server is not connected." Is there a way to fix this?
    thanks
  2. DJHiP
    Dec 2, 2009
    29
    Are you able to restore windows to a backup to take it back to 8.0?
    3CX have not listed 8.1 as an officially supported OS yet, it might be safer to stay on 8.0 for now..
  3. KenC
    Mar 29, 2012
    85
    reinstalled v11sp4 and it works ok now.
    thank you.
