V12.5.32 - No Network on Ubiquiti UVP
Discussion in 'Android' started by Grand Archer, May 27, 2015.
  1. Grand Archer
    May 27, 2015
    6
    Device Info
    Phone Model: Ubiquiti Unifi UVP
    UVP Firmware Version: 4.6.4.383
    Android Version: 4.4.2
    3CX App Version: 12.5.32
    Issue Info
    Handset: Phone|Speakerphone w/MIC|BT
    Contacts: Local|Google
    Connection: Wired
    Server: Internal
    The UVP phone from Ubiquiti does not have WiFi or Cellular but a Wired Network connection. So when the 3CX app launches in android on the phone it shows no network and the account does not register even after clicking register. Only after clicking on the selector by the account under settings does it register but still shows no network. A provision in the Android 3CX app needs to be put in to account for wired connections. Thank You.
    11,095
    327
    Given that the vast majority of Android devices being used (at this time), are probably wireless, you may have a bit of a wait for this feature. The proper place to submit a feature suggestion is here.
    http://www.3cx.com/ideas/index.php
  3. Grand Archer
    May 27, 2015
    6
    I would have put it in the feature request section if I had believed it to be a feature request. Simply stated this is not a needed feature more than a bug that needs resolved.
  4. ian.watts
    ian.watts Active Member
    Apr 8, 2011
    532
    Perhaps I need new firmware.. but my experience with trying 3CXPhone for Andoid on a UVP is that the Google Play Store reports the app and device are not compatible.
    So.. unless the updates address, you hacked the APK onto the UVP.
    I guess it'd first be nice to know if the app is supposed to be compatible with the device as per 3CX.
    If not, the rest is fun and all but not really supported anyway.
  5. Grand Archer
    May 27, 2015
    6
    I didn't have to do anything special to get the app on the device. I simply installed it from the Play Store. Not sure what issue your having but perhaps you should try the new firmware to see if it fixes your issue.
  6. ian.watts
    Apr 8, 2011
    532
    Given the last GA was 4.6.3, the fw is beta to begin with.
    Went to 4.6.4.305.. nope.
    But I'll see when I see.
