V12.5 - Number of digits - Extensions
Discussion in '3CX Phone System - General' started by Futureweb, Nov 6, 2015.
  1. Futureweb
    Futureweb New Member
    Jun 29, 2015
    162
    10
    is there any possibility to change to Number of Digits from 3 to 4 - without reinstalling / reconfiguring everything from Scratch?
    Just tried reinstall + Backup Restore - but the Backup of course also restores 3 Digit Extensions ... :-/
    Thx
    Andreas Schnederle-Wagner
  2. CentrexJ
    CentrexJ Member
    May 5, 2009
    383
    52
    No, not if you want your system to work properly. I suggest exporting the extensions to CSV and uninstall/reinstall new system. Edit the CSV file to the new extensions and import. That will save most of the work setting up the new system.
  3. Futureweb
    Jun 29, 2015
    162
    10
    I feared this answer will come ... ;-)
    One big Problem with that - extensions Export won't export Rulesets, Phone Provisioning (BLFs, ...) and lot's of other Stuff ... so with lot's of Extensions thats still a pain in the a...
    Andreas
  4. CentrexJ
    CentrexJ Member
    May 5, 2009
    383
    52
    Good point. I try to be consistent with blf and rule provisioning so the multselect and edit feature of the management console is a lifesaver on large systems. Then you only have to customize the people who need different.
