V12 And CTI
Discussion in '3CX Phone System - General' started by jasonhayes, Oct 2, 2013.
  1. jasonhayes
    jasonhayes New Member
    May 9, 2012
    140
    10
    Playing with V12 (free version), as too scared to install for real in the Office. I used to use some non-support (hardware) phones, which just didn't wont to work with V12 and using the Windows version of 3CX Phone. I have now provisioned the Yealink T20 phone and all is good, except.... I can not dial a number via the Windows 3CX phone and get it to ring the Yealink T20. This is a feature we use a lot and don't want to lose. Is this just because I using a trial version? When I try I dial the number and nothing happens. If I change it from CTI to 3CX Phone, it does dial the number and I can hear the T20 ring via my PC Speakers. Can setup V12 using my V11 Licence and test or will it cause issues with the Office versions?
  2. rogueblackburn
    Aug 11, 2013
    42
    CTI is not linked to a commercial license, but you may want to check the firmware of the phone and make sure it's at the correct level. Use the V12 demo key license to test out all features, you can find it under the Blog / Releases, along with all other important donwload links for the V12. And NO, don't set up a second PBX with your commercial license, it will get blocked.
  3. jpillow
    jpillow Well-Known Member
    Jun 20, 2011
    1,342
    Have you taken a look at the server activity log, or wireshark (excuding WAN IP etc)? you may want to take a look or post if possiby replicating the issue because what you have here doesnt realyl give enough information to get much assistance.
