V12 desktop components
Discussion in '3CX Phone System - General' started by nickjhunt, Sep 18, 2013.
  1. nickjhunt
    Apr 25, 2013
    42
    Where do I find the desktop components for V12?
  2. davidbenwell
    davidbenwell Active Member
    Apr 27, 2010
    704
    there is no desktop components for V12 as its no longer using the My Phone Application.
    if you are wanting to use outlook with the Windows Softphone V8 then you will need to download the http://downloads.3cx.com/downloads/3CXCRM12.exe CRM Module
  3. nickjhunt
    Apr 25, 2013
    42
    So in order to continue using outlook integration I have to purchase another product? :S :S :S
