v12 Multiple Registrations to same provider
Discussion in '3CX Phone System - General' started by craigreilly, Apr 4, 2014.
  1. craigreilly
    craigreilly Well-Known Member
    Feb 1, 2012
    3,575
    305
    Anyone using the same provider with 2 separate accounts and requires registration for in and outbound calls in v12?
    (basically 2 VoIP Provider entries for same provider)
    Show of hands please...
  2. jpillow
    jpillow Well-Known Member
    Jun 20, 2011
    1,342
    Yes I have this setup at a couple of locations, client has Broadvox 6 unlimited local trunks and 3 unlimited LD trunks. Both are registered to the same pbx, and Broadvox does require registration. Is there any reason in particular you ask?
  3. craigreilly
    Feb 1, 2012
    3,575
    305
    In my findings, they register fine but the wrong password is sent when placing a call thus it gets forbidden.
    It works fine for me in v11.
    The provider is already working with 3 cx to fix the issue. I am surprised to hear you have this working...
  4. sigma1
    sigma1 Active Member
    Nov 20, 2009
    542
    John:
    I am very surprised about that too. Is that 2 accounts (user name/password) on the same Server IP uri? I see that they can register but only one trunk works the other gets forbidden.
  5. jpillow
    Jun 20, 2011
    1,342
    I completely missed the V12 comment, client is using V11 at each location... Each location has both trunks registered to the same pbx but again this is V11.
  6. craigreilly
    Feb 1, 2012
    3,575
    305
    Thanks for the post back... Hopefully this will be resolved in quick order...
  7. jpillow
    Jun 20, 2011
    1,342
    So just to verify your saying this is like a known bug, correct?.... Glad I saw this post.
  8. craigreilly
    Feb 1, 2012
    3,575
    305
    It has been submitted as a bug to support.
  9. craigreilly
    Feb 1, 2012
    3,575
    305
    It appears this may be an issue with the From: User Part.
    I normally change this from AuthID, to Originator Caller ID or Extension Caller ID.
    This works fine for the first registered account.
    But subsequent accounts send the wrong header info and the call fails.
    This seems to work fine on a Grandstream UCM, and other systems, just fine.
    And I recall it working fine in v11.
