v12 Phones Tab
Discussion in '3CX Phone System - General' started by craigreilly, Mar 10, 2014.
  1. craigreilly
    craigreilly Well-Known Member
    Feb 1, 2012
    3,575
    305
    So we just upgraded to v12. We have clicked all the phones and selected REPROVISION PHONES.
    They all went away and came back up and are working.
    The status of every device shows no MAC ADDRESS, status="Reprovision Required"m and the "Launch Phone Interface" is greyed out.
    I am logged in to 3cx as ADMIN.
  2. netswork
    netswork Active Member
    Mar 11, 2011
    577
    That happened to my systems with polycom phones when I upgraded to v12. I have yet to figure out how to resolve it. I get the launch phone interface but reprovision is grayed out. the MAC address says "unprovisioned" on all extensions.
  3. craigreilly
    Feb 1, 2012
    3,575
    305
    strange. As I go into the extension and hit SAVE - the "Reprovision Request" goes away, still no MAC Address, still no Launch Phone Interface.
    When I hit save, I am on the Phone tab and notice the MAC goes from mixed case to uppercase.
  4. craigreilly
    Feb 1, 2012
    3,575
    305
    So I figured out the issue - my phones were still assigned to my custom template.
    Once I changed to the template that came with v12 the Phones screen worked as needed.
    I just needed to add in my customizations to the new template file...
  5. netswork
    Mar 11, 2011
    577
    I guess I will have to use a program to compare the two. It was over a year ago when I made those templates. Glad you found a fix!
  6. craigreilly
    Feb 1, 2012
    3,575
    305
    We only had a few customizations so it was fairly easy.
    -custom XML phonebook (takes 3cx and added info from Active Directory mobile phones)
    -all phones get Shared Parks - SP1,2,3,4,5
    -all phones have a Multicast listener and Multicast button to send pages
    -turn off the key tone when dialiong
    -all phones get the RECORD button to record conversations
    -DND button is set for *32 and *30 instead of *6x
  7. carolinainnovative
    May 4, 2009
    369
    6
    I highly recommend WinMerge or, for something with fewer bells and whistles, try using notepad++... it has a "compare" feature as a plugin. If it isn't showing under the plugins menu, go to plugins -> plugin manager -> show plugin manager. Find "Compare", add it, restart Notepad++.
    "ok, what's new in the template, THIS time?"
  8. craigreilly
    Feb 1, 2012
    3,575
    305
    Thanks for the recommendation...
  9. netswork
    Mar 11, 2011
    577
    Ya I like notepad++
