v12 Provisioning error
Discussion in '3CX Phone System - General' started by fioreit, Mar 3, 2014.
  1. fioreit
    Apr 6, 2012
    23
    Just starting to test out 3cx v12. Installed on Windows Server 2012 Standard with IIS.
    After install and reboot, whenever I click on the "Phone Provisioning" under "Settings, I get an error. See attachment below.
    Its also worth noting that Phone Provisioning doesn't seem to be working at all either. The system is not auto generating the Configuration files for any extensions.
  2. sigma1
    sigma1 Active Member
    Nov 20, 2009
    542
    What phone model did you select when you received that warning?
  3. fioreit
    Apr 6, 2012
    23
    None. Just clicking Phone Provisioning pops up the error.
  4. jpillow
    jpillow Well-Known Member
    Jun 20, 2011
    1,342
    I would check under services to assure all the services are running, if so I'd then backup uninstall, and reinsall.
  5. MichaelB
    MichaelB 3CX Team
    3CX Support
    Aug 25, 2009
    415
    19
    First and foremost I would like you to check why the local ip interface in the attachment provided is blank.
    This is the cause of the exception.
    The Local IP Address SHOULD NEVER be blank/empty.
    Check Log folder, Wizard.log especially or Backup and Restrore.log incase you made a restore.
