V14.0.27-3cxconfig file not working
Discussion in 'Android' started by tobiastromm, Jul 16, 2015.
  1. tobiastromm
    tobiastromm New Member
    Jun 26, 2010
    138
    Hi.
    I am trying to configure my android client with the .3cxconfig file provided by e-mail, but, after download the file to my android phone it open with Kingsoft Office instead of 3CXPhone for Android.
    How can I fix it?
    Using the "Assign to Extension" under 3CX Server is working OK.
    Phone Model: [HP Slate 6 Voice Tab]
    Firmware Version: [v1.01.07_20141017.43752]
    Android Version: [4.4.2]
  2. pj3cx
    pj3cx Active Member
    Aug 1, 2013
    646
    Hi there,
    Can you try to uninstall 3CXPhone, and reinstall, this should recreate the file association.
  3. tobiastromm
    Jun 26, 2010
    138
    That not solve the problem.
    I am having the same problem with another phone model.
    I should use the same provision file that work for 3CXPhone for Windows right?
    Thanks.
  4. pj3cx
    pj3cx Active Member
    Aug 1, 2013
    646
    Yes but you must send it through a normal welcome email, opened on your mail client on android
  5. tobiastromm
    Jun 26, 2010
    138
    Hm...
    Then it do not work with Gmail App.
    Thanks.
  6. Anonymous
    Anonymous Guest
    I found the same behavior in some testing. I also was able to work around it by SAVING the attached config file out of the Mail client and then opening via a file browser. This behavior only showed on the Android 5.0X phones that I tested. It seems that the Default Android 5.0X mail client doesn't quite obey all the OS file association rules.
