v14.0.47 - Calling over WiFi
Discussion in 'Android' started by JasonNZ, Oct 13, 2015.
  1. JasonNZ
    Oct 13, 2015
    Device Info
    Phone Model: LG Nexus 5
    Android Version: 6.0
    Phone Model: Sony LT26w
    Android Version: 4.1.2
    Issue Info
    Handset: Phone
    Contacts: Local
    Connection: WiFi
    Server: Internal
    Calling over WiFi is inaudible, this is using the latest version of 3cx v14.0.47
    We have verified the settings for our firewall and it works fine with iOS version of 3cx.
  2. MichaelB
    MichaelB Member
    3CX Support
    Aug 25, 2009
    407
    8
    Hi, Could you please do the following,
    Go to Settings > Audio Options > Microphone Source and change from Default "Advanced Mode" to "Basic Mode".
    Tell me how this will go and restart your phone.
