v14 backup restore in v15 setup using different licence key
Discussion in '3CX Phone System - General' started by kurt5132081, Mar 27, 2018.
  1. kurt5132081
    May 11, 2017
    44
    Hi Guys
    Ok, i created a post before asking this question (see below), post has been closed hence me creating this one.
    I followed the advice given to me and it worked, managed to create the backup without the license attached.
    however when using the backup i created in a V15 install the config still does not get restored, no extensions,queues,DR's get restored.
    https://www.3cx.com/community/threa...-using-a-different-license.54754/#post-226737
    10,737
    278
    Please clarify... you are restoring, using a backup from V15, or from V14 (as indicated in the title)?
    You say "it worked", so.... what worked and exactly what. isn't?
  3. kurt5132081
    May 11, 2017
    44
    I am using a version 14 backup and restoring it during a v15 install.
    when i said it worked, i was referring to the process of creating a v14 backup without the license attached.
    So when i take the v14 backup i created, run the v15 install and select restore from existing backup, after the setup has completed i basically have a bare install, nothing gets restored from backup
  4. NickD_3CX
    NickD_3CX Support Team
    Jun 2, 2014
    1,327
    73
    If you want, upload the backup file to a file sharing site of your choice and send me a PM with the download link to it. I can check the backup to here and see why this is happening.
  5. CentrexJ
    CentrexJ Member
    May 5, 2009
    432
    67
    Can you double check that in your v14 the license shows as the free version? If so are you sure you used the backup ZIP created after the v14 was showing running the free version?
    I did an upgrade for a client like this two weeks ago and it worked perfect.
  6. kurt5132081
    May 11, 2017
    44
    Hi NickD
    thanks, will do that.
  7. kurt5132081
    May 11, 2017
    44
    Hi Centrexj
    Positive that when the backup was done it had no license attached, also that i am using the correct ZIP
  8. kurt5132081
    May 11, 2017
    44
    one other question i would like to ask, once i have done the upgrade from v14 to v15 is it still possible for me to roll back to v14. ie Turn off the v15 server and power up the v14 server?
  9. techdummy
    techdummy New Member
    Sep 22, 2017
    182
    9
    From what you have told, it looks like you have 2 servers, one running V14 and other V15.
    If that is the case, you can rollback to v14 without any issues.
