V14 Closing Client FYI
Discussion in 'Windows' started by petewatterschats, Mar 22, 2016.
  1. petewatterschats
    petewatterschats New Member
    Jan 19, 2016
    151
    This is an FYI since there is a way arround this issue
    On the Windows Soft Client when the system boots the 3CX Client is launched and all is well.
    If you click the "X" in the upper right corner of the client it closes but when you click the client to re-launch it the Client does not come-up.
    Went to task manager and saw that the 3CXWin8Phone.exe*32 process was not closed with the client.
    Stopped the process, clicked the client icon and it now came up
    If you go to settings - exit Client you do not have this issue
  2. cfive
    cfive Member
    Aug 20, 2009
    284
    5
    I don't think X closes the client, just minimizes it. It should still be visible in the notification area.
