V14 Custom Template Variables
Discussion in 'Ideas' started by DSXDATA, Jan 22, 2016.
  1. DSXDATA
    DSXDATA New Member
    Oct 20, 2015
    192
    66
    Some devices require special tweaking in the templates for special circumstances. For example, Yealink T4X phones can overdrive the audio volume on the handset which results in echo and amplification of local noise. When clients complain, we have to adjust the audio settings in the template. It would be so very nice to have a table of 5 custom variables that we could use in these circumstances like so:
    audio.handset_send = %%USERVAR01%%
  2. Zahed Kelani
    Dec 22, 2015
    5
    I vote for this option.
    I think there is a way to make global custom parameters, but not per user.
    It should be available as per extension. multiple custom variables (that can be increased as needed. just like BLF) would be even better. which can be configured from extension tab or extension *.CSV import file.
    %%USERVAR01%%
    %%USERVAR02%%
    %%USERVAR03%%
    etc...
