V14 force MakeCall rather than CTI mode
Discussion in '3CX Phone System - General' started by nickjhunt, Nov 2, 2015.
  1. nickjhunt
    Apr 25, 2013
    42
    I am running V14Sp1 and need to be able to accept multiple calls on my extension. The 3CX softphone however has a habit of auto answering some of these calls. I am aware that there is an issue with the way that CTI runs that precludes accepting multiple calls but I cannot seen to be able to disable CTI. I have the 'Use intercom for make call' de-selected but it still does it.
    Phone is a grandstreamGXP2124 which I am aware is no longer supported but it was when we purchased loads of them when we introduced 3CX
  2. craigreilly
    craigreilly Well-Known Member
    Feb 1, 2012
    2,947
    179
    My Grand-stream 2130's use MakeCall and also do not have issues with CTI as far as I know.
    Although this is for Yealink, perhaps the same option applies:
    http://forum.yealink.com/forum/archive/index.php?thread-2430-3.html
    There is an XML file that needs a mod on the server.
    C:\ProgramData\3CX\Data\Http\Interface\MyPhone\cti_template.xml
    You remove the URL for Answer_Call
  3. nickjhunt
    Apr 25, 2013
    42
    Thank you, just what I was looking for.
  4. CentrexJ
    CentrexJ Member
    May 5, 2009
    383
    52
    Thanks for this. Do the services need to restart after applying the change?
  5. craigreilly
    Feb 1, 2012
    2,947
    179
    i understood IISRESET only, then exit 3cxPhone and reopen.
    (Remember to terminate it completely and not just "X" as that minimizes it to the Notification area only.)
