v14 "HTTP Error 404. The requested resource is not found" Default Site
Discussion in 'Windows' started by Informatics, Oct 27, 2016.
  1. Informatics
    Oct 26, 2010
    7
    I've installed the 3cx Software 4 times making sure I didn't miss anything and even completely backed out and removed the IIS role from the server. After a restart I tried the install again. Same result.
    I can bring the Management console up via the public facing FQDN (on the server) but double click on the icon placed on the desktop simple gives me "HTTP Error 404. The requested resource is not found."
    Help, please.
    Thanks ahead of time for your assistance.
    11,262
    355
    If you right click on the icon, then select properties, where does it "point" to? You could edit that to take you to the correct location. I'm not certain why it is incorrect.
  3. Informatics
    Oct 26, 2010
    7
    Thanks for replying!
    The URL is going to the 'Default web Site'. URL is pointing to our internal domain:
    3cxv14.XX.XXXXXXXXXXX.com:80/management
    It resolves properly but stating that the folder doesn't exist.
  4. leejor
    11,262
    355
  5. Informatics
    Oct 26, 2010
    7
    Under 12.5 it was :5000. With v14 it changed to :80. Just to be clear, I've done nothing other then fill in the values during the installation.
    Browse from my desk and receive this error:
    404 - File or directory not found.
    The resource you are looking for might have been removed, had its name changed, or is temporarily unavailable.
    Locally on the server:
    Detailed Error Information:
    Module IIS Web Core
    Notification MapRequestHandler
    Handler StaticFile
    Error Code 0x80070002
    Requested URL http://3cxv14.XX.XXXXXXXXXXX.com:80/management
    Physical Path C:\inetpub\wwwroot\management
    Logon Method Anonymous
    Logon User Anonymous
    The folder is completely missing
  6. leejor
    11,262
    355
    Might be grasping at straws, but have you tried "Run as Administrator"?
  7. Informatics
    Oct 26, 2010
    7
    Tried that on the first day. The 3cx installation created a shortcut to a web folder that doesn't exist.
    Another point that I need to make that isn't clear to me: Under Default Web Site is '3CXCloudWebService'. The other Site other then Default Web Site is instance01.
