v14 initiate calls from outlook via desk phone
Discussion in '3CX Phone System - General' started by agila, Sep 9, 2015.
  1. agila
    Aug 27, 2015
    as the subject suggests looking to initiate calls from outlook 2010/2013 which goes is then passed to the desktop phone.
    have seen there was a 3cx assistant for v12 but so far have not been able to download this as can't seem to find the dload.
    does anyone know if this is something that V14 can do or is it only usable via soft phone
    thanks
  2. Saqqara
    Saqqara Active Member
    Mar 12, 2014
    877
    135
    Install 3CXPhone in CTI mode - http://downloads.3cx.com/downloads/3CXPhoneforWindows14.msi , http://www.3cx.com/docs/3cxphone-deployment-administration/
    Within the console, you probably need to check / change extension settings under the 3CXPhone tab
    Download the plugin for Outlook - http://www.3cx.com/docs/microsoft-outlook/
  3. agila
    Aug 27, 2015
    thank you very much
