V14 - Phone Provisioning Templates
Discussion in '3CX Phone System - General' started by Futureweb, Oct 14, 2015.
  1. Futureweb
    Futureweb New Member
    Jun 29, 2015
    163
    17
    is it possible to delete/deactivate unused Phone-Provisioning Templates?
    Thank you
    Andreas Schnederle-Wagner
  2. pj3cx
    pj3cx Active Member
    Aug 1, 2013
    646
    Hi there,
    Yes you may delete templates from C:\ProgramData\3CX\InstanceXX\Data\Http\Templates\phones and custom templates from C:\ProgramData\3CX\InstanceXX\Data\Http\Interface\provisioning\%provsubdir%\CustomTemplates
    Restart the web server afterwards so that the change is seen by the phone system.
