V14 - Push notifications to iPhone not working?
Discussion in 'iOS' started by Ratcliffes, Oct 10, 2015.
  1. Ratcliffes
    Sep 26, 2015
    9
    Device Info
    Phone Model: iPhone
    Generation: 6s
    Firmware Version: 9.0.2
    Jailbreak: NO
    Cydia Installed: NO
    Issue Info
    Handset: Phone
    Contacts: Exchange
    Connection: WiFi and 3G
    Server: Internal
    We are running v14 of 3cx with latest updates installed.
    The most up to date version of the 3cx iOS app is installed on a new iPhone 6s.
    The phone will register with the PBX correctly without an issue but if the phone is locked with the app running in the background or if another app takes the focus, the phone will not ring during an incoming call. No push notification is received. We have been through the troubleshooting steps to confirm that the firewall on the PBX is not blocking the various ports used for push. Also push notification is enabled for the extensions affected. Anyone know what to do next to solve?
    Steve Ratcliffe
  2. Vali_3CX
    Vali_3CX Well-Known Member
    Dec 12, 2008
    1,482
    67
    Hi Steve
    Assuming everything is set OK in order for push notification to work, the only possible reason remaining is a missing/expired/wrong push certificate on the PBX. Since I'm not familiar with the PBX installation/deployment/management, I suggest you to contact our tech support. Such case may happen due to an incorrect PBX update or backup/restore.
    Regards
    vali
  3. Ratcliffes
    Sep 26, 2015
    9
    Thanks Vali. Will contact Support.
    Steve
  4. Ratcliffes
    Sep 26, 2015
    9
    Just to confirm - Reinstallation of a fresh certificate supplied by the support team has fixed this issue for us.
  5. igor.snezhko
    igor.snezhko Active Member
    Jan 7, 2008
    667
    7
    Do you receive PUSH notifications on Chat messages also? I receive call PUSH notofications, but not receive chat push notifications.
  6. NickD_3CX
    NickD_3CX Support Team
    Jun 2, 2014
    1,344
    78
    As far as I remember PUSH is only sent for incoming calls at the moment.
  7. Vali_3CX
    Dec 12, 2008
    1,482
    67
    Hi Igor
    I confirm what NickD said: at this moment, push notification is implemented only for incoming SIP calls.
    Regards
    vali
  8. igor.snezhko
    Jan 7, 2008
    667
    7
    Here http://www.3cx.com/docs/firewall-router ... c6dep4icl2 we see
    Configuring ports to allow PUSH messages to smartphones
    PUSH messages are sent by 3CX Phone System to Extensions using smartphones in order to wake up the devices to take calls or messages. This greatly enhances the usability of the smartphone clients but requires configuration of the firewall to allow outbound PUSH messages.
  9. NickD_3CX
    Jun 2, 2014
    1,344
    78
    Corrected the blog post
  10. tim942
    Jul 30, 2015
    68
    6
    Similar issue as above, but I purposefully disabled the PUSH notifications via the checkbox as we could not answer from lock screen at the time. Seeing as they list this fixed in the changelog, I want to test this but cannot find the checkbox after service pack. I have enabled the extensions but I do not see the push client register as before nor do I see any traffic across port 2195 (port specified in Parameters). Is there a parameter I can reset in order to enable this?
  11. NickD_3CX
    Jun 2, 2014
    1,344
    78
    I don't quite get which checkbox you can't find.
    Also you say that you see no traffic over port 2195, but despite that, is PUSH working?
    Try removing the account from the phone and sending a new Welcome Email if you have not done that already.
    If that doesn't work, as Vali said above, it might be a case of an missing/expired/wrong push certificate, so I would recommend you contact the Support Team.
