Solved V14 REPORT_URL I need to set it from ip to domain name.
Discussion in '3CX Phone System - General' started by waranon, Dec 22, 2016.
  1. waranon
    Dec 22, 2016
    10
  2. YiannisH_3CX
    YiannisH_3CX Support Team
    May 10, 2016
    7,400
    535
    Hi there,
    given that you have set the PBX up with external FQDN and Internal IP then if you navigate to Call Reports/Settings then you have the option to choose the link you want.
  3. waranon
    Dec 22, 2016
    10
    Thanks Its work.
  4. DaveH
    Feb 4, 2017
    5
    Can this be done in v15. I'm looking in Call Reports --> Settings and I only see Logo and Clear Report options.
  5. YiannisH_3CX
    May 10, 2016
    7,400
    535
    In V15 both links are sent into the report without having to choose which one you want through the management console
  6. DaveH
    Feb 4, 2017
    5
    Opps... I use Thunderbird for email, and the image button for the external link wasn't showing, so I was only seeing the internal link.
    Thanks.
