V14 Reports not sending
Discussion in '3CX Phone System - General' started by fronzo, Sep 8, 2015.
  1. fronzo
    Sep 8, 2015
    5
    Hi everybody.
    I have some issues with the new v14 reporting features.
    I tried to generate both "on-the-fly" reports and scheduled ones, with no luck: in both cases nothing arrives to the specified destination email.
    Email settings on server are correct: other emails are sent normally.
    Server/Phone system logs show no relevant rows.
    Any advice?
    Thanks in advance.
  2. pj3cx
    pj3cx Active Member
    Aug 1, 2013
    646
    Hi there,
    Please open a support ticket (yourself or through your reseller) so that this can be investigated further.
  3. fronzo
    Sep 8, 2015
    5
    Thanks.
    Could you please tell me how to open a ticket directly?
    I don't have access to support.3cx.com, but I have an active maintenance plan and we are in the process of becoming registered partners.
    Oddly, searching for "reports", a record related to my issue is found (http://i.imgur.com/VOI0woD.png), but I have no access to it.
    This is the solution url: http://support.3cx.com/index.php?/Knowledgebase/Article/View/212/0/reports-not-delivering-on-v14
    Tks!
  4. fronzo
    Sep 8, 2015
    5
    Any advice?
    Thanks!
  5. Cjay
    Cjay New Member
    Feb 24, 2007
    189
    Hmm, same problem. Worked once, but now nothing. Did you manage to resolve this?
  6. fronzo
    Sep 8, 2015
    5
    Nope. I'll try to open a ticket next week. Apparently the solution I found (that I couldn't read) on the support portal disappeared. :(
  7. adrianc
    Sep 4, 2015
    20
    I've had this too.
    Reports work one minute and then don't the next but nothing has been changed.
    I like the idea of scheduled reports but the whole reporting method (including listening to recorded calls from the report) was better implemented in 12.5.
  8. igpabal
    Aug 27, 2014
    I had the same problem.
    My problem was that I was entering incorrectly to the management console
    In v12.5 the url was http://IP_PBX:5000/MainForm.wgx
    In v14 the new url is http://IP_PBX:5000/management/MainForm.wgx
    When I access with the new url it sent me the report correctly.
  9. fronzo
    Sep 8, 2015
    5
    Unbelievable! It works!
    Thanks a lot!! 8) 8)
  10. adrianc
    Sep 4, 2015
    20
    Worked for me too.
    So simple when you know the answer.
    Thanks!
  11. jayson@brctrucks.com
    Sep 8, 2015
    9
    I have the exact issue described here. But... when I log in with http://IP_PBX:5000/management/MainForm.wgx, the only thing that changes is it actually shows up in the scheduled reports now for about 5 seconds with the status saying "running", then it disappears and I have yet to receive an email. I am not coming from v12 though this is a fresh v14.
    Welcome emails and such work I just have yet to see a report....
  12. MichaelB
    MichaelB Member
    3CX Support
    Aug 25, 2009
    407
    8
    @jayson could you please provide callhistory.log and send me an email mb@3cx.com
  13. jayson@brctrucks.com
    Sep 8, 2015
    9
    Thanks MichaelB for pointing me in the right direction.
    Apparently the "aspmx.l.google.com" server I was using will send welcome emails fine but not call reports. I switched to "smtp.gmail.com" with ssl/tls and now both work just fine.
