v14 Reports not working at all
Discussion in '3CX Phone System - General' started by TSlocum, Dec 8, 2015.
  1. TSlocum
    TSlocum New Member
    Oct 15, 2013
    225
    15
    When I try to run a report, I get the email but the link goes to a 404 error. What gives? How do I fix this crap?
    I've tried pdf, html, etc, and nothing.
    What time do scheduled reports run? You can only choose day, week, etc, but not time? Also the email template paramater %%REPORT_NAME% doesn't work, it just comes through blank.
    The new reporting setup is abysmal at best. Each day I'm learning that upgrading to v14 was a mistake.
  2. nb
    nb Support Team
    Jun 7, 2007
    2,153
    172
    I sent you an email - lets check this out - Maybe it is something conflicting with a redirect..
