V14 Run reports > 30 days
Discussion in '3CX Phone System - General' started by bmcdevitt, Apr 21, 2016.
  1. bmcdevitt
    Feb 19, 2013
    37
    After the last update I don't see any options for running reports that go back further than 30 days.
    I need to get some 2015 Summary reports complete how would I go about doing that?
    I had to convert all old report data to newer format so I hope I didn't sit there for 30 min for nothing :)
    -Ben
  2. bmcdevitt
    Feb 19, 2013
    37
  3. CentrexJ
    CentrexJ Member
    May 5, 2009
    388
    52
    When choosing the date range, choose "Custom" and enter the range you want. The "pre-set" dates go up to 30 days but you can put any valid date into the "custom" date range and it works fine.
  4. bmcdevitt
    Feb 19, 2013
    37
    Thank you!
