V14 sp2 download
Discussion in '3CX Phone System - General' started by garypharr, Dec 2, 2015.
  1. garypharr
    Sep 5, 2013
    12
    I cannot get the management console to download and install the sp2 update. I see that there is a manual download available. Does that get installed like a full refresh by backing up, uninstalling etc?
  2. nikosT_3cx
    3CX Support
    Jun 2, 2014
    57
    please note that a Service Pack does not require, backup, uninstall and re-install.
    Do you have valid maintenance on your license key ?
    Do you have any Proxy on the system ?
