V14 SP2 some windows phones do not show presence info
Discussion in 'Windows' started by oakley, Jan 14, 2016.
  1. oakley
    Aug 10, 2012
    19
    I have just upgraded to V14 SP2 and installed the Windows Phone over the top of the V12 that was installed on the PCs. Some PCs show presence info and other do not. I have disabled the windows fw on the ones that do not show presence but this does not help. I have uninstalled the V14 windows phone and installed again but this did not help
    Any idea what is wrong?
  2. NickD_3CX
    NickD_3CX Support Team
    Jun 2, 2014
    1,375
    84
    Usually when you don't get presence information it is because the 3CX Phone cannot access the 3CX Server on its HTTP/S ports you have set.
    The most common reasons for this are:
    1) Firewall or AntiVirus software on the 3CX Phone and/or 3CX Server machines (uninstall and restart the machine to check).
    2) Manually provisioning the 3CX Phone app.
    3) Not having forwarded the HTTP/S ports on the firewall (by the time some work though I doubt this is it).
