v14 SP3: Voicemails are not always emailed to user
Discussion in '3CX Phone System - General' started by 3cx_user_supporter, Mar 21, 2016.
  1. 3cx_user_supporter
    Mar 21, 2016
    We upgraded to v14 SP3 last week and have since then noticed some strange behavior.
    Voicemail for some extensions have been set to 'mail and delete'. This has worked great for several years, but since last week some users started complaining that they did not receive emails with the voicemail attached.
    We verified the mail server setup. Test emails and welcome emails are sent correctly.
    Looking in c:\programdata\3cx\instance1\data\ivr\voicemail\extensions under the actual extensions we found voicemails. The error code states "E-mail delivery stopped after 72 hours of retries".
    We tried to change the emails address on the extension with no effect. We then changed from 'mail and delete' to 'send notification' and could suddenly receive notification emails. Afterwards we changed to "mail and delete" and now it seems to work.
    1) Has anyone experienced the same?
    2) Any way to trigger the system to retry the voicemails that has timed out after 72 hours?
  2. complex1
    complex1 Active Member
    Jan 25, 2010
    814
    49
    Did you make a version upgrade or a service pack update?
    If you did a version upgrade, from which version you upgrade from? v12 or v12.5?
    My experience is that if you upgrade from v12 to v14 you have to check all settings of the new version, because a lot of the settings are wrong or not copied.
    If your previous version was v12.5 the upgrade is more reliable.
  3. 3cx_user_supporter
    Mar 21, 2016
    The upgrade was from v14 SP2 to v14 SP3. Seemed to run without issues at the time.
