- Joined
- Jan 11, 2016
- Messages
- 178
- Reaction score
- 10
We have a site running V14 SP3 49169.513 with around 180 Yealink T23G phones, recently a small number of phones briefly lose registration and then re-register. This has only started happening since 2 recent changes:
1. The server was moved offsite.
2. All the HP switches were changed out for Cisco ones.
This is the activity log from one of the more severely affected phones:
20-Oct-2016 11:24:55.575 [CM504001]: Endpoint Extn:1944: new contact is registered. Contact(s): [sip:[email protected]:5060 / 1944]
20-Oct-2016 11:24:18.653 [CM504002]: Endpoint Extn:1944: a contact is unregistered. Contact(s): []
20-Oct-2016 11:14:50.062 [CM504001]: Endpoint Extn:1944: new contact is registered. Contact(s): [sip:[email protected]:5060 / 1944]
20-Oct-2016 11:13:48.205 [CM504002]: Endpoint Extn:1944: a contact is unregistered. Contact(s): []
20-Oct-2016 10:33:10.074 [CM504001]: Endpoint Extn:1944: new contact is registered. Contact(s): [sip:[email protected]:5060 / 1944]
20-Oct-2016 10:32:46.049 [CM504002]: Endpoint Extn:1944: a contact is unregistered. Contact(s): []
20-Oct-2016 09:25:57.452 [CM504001]: Endpoint Extn:1944: new contact is registered. Contact(s): [sip:[email protected]:5060 / 1944]
20-Oct-2016 09:25:13.057 [CM504002]: Endpoint Extn:1944: a contact is unregistered. Contact(s): []
20-Oct-2016 09:21:24.474 [CM504001]: Endpoint Extn:1944: new contact is registered. Contact(s): [sip:[email protected]:5060 / 1944]
20-Oct-2016 09:20:42.831 [CM504002]: Endpoint Extn:1944: a contact is unregistered. Contact(s): []
It only seems to affect a small number of the phones, around 10% although as seen above it affects some phones so badly the user has given up using it!
Any idea's which of the 2 changes are likely to have caused this issue?
