V14 Sporadic one way audio
Discussion in '3CX Phone System - General' started by RobertKroll, Oct 30, 2015.
  1. RobertKroll
    Nov 16, 2008
    42
    I have been using 3cx for many years and I seem to be having an issue I simply just can't solve. I have a deployment that I am using that seems to be experiencing one way audio several times during the day. I reset all services and the system is up and running again for a few hours until the next time. I haven't changed any settings in the system since upgrading to v14 so I am hoping somebody can assist. My system overview:
    SonicWALL NSA2600
    Windows server 2012 Hyper-V w/4 guest operating systems
    Windows server 2012 running 3cx v14
    Yealink T-28 telephones (x15)
    2 remote 3cx softphones
    2 remote telephones via VPN (SonicWALL TZ105)
    I haven't noticed anything in the event logs or the 3cx server logs (Unless I am missing something that somebody more educated than I may notice).
    If you can assist, I would be appreciative.
    Regards,
    Robert Kroll
  2. bardissi
    bardissi Member
    Jan 31, 2012
    318
    Two things come to mind.
    1. Network / router / isp issues
    2. Vm Host resource issue.
  3. RobertKroll
    Nov 16, 2008
    42
    Thank you for the reply, can you elaborate? I have checked, but cannot find issues.
  4. bardissi
    bardissi Member
    Jan 31, 2012
    318
    First things first, are you running the sonicwall hot fix ?
  5. adrianc
    Sep 4, 2015
    20
    Robert
    We have an NSA 2600 running with 3CX 12 without any issues of audio.
    It's running firmware SonicOS Enhanced 6.2.2.1-14n--HF156374-6n but the hotfix number is NOT for anything 3CX related.
  6. RobertKroll
    Nov 16, 2008
    42
    Thank you for the input. Your input prompted me to check the firmware. The problem was indeed a firmware issue. What was happening is that the SonicWALL was remapping the ports which was a bug in the firmware. Performed the following:
    Disabled remapping on outgoing NAT policy.
    Turned off Consistent NAT.
    Turned off STUN on PBX.
    Restarted all services.
    So far, 48 hours, so good...
    Regards
  7. adrianc
    Sep 4, 2015
    20
    Hi Robert
    Which version of firmware are you running now?
    Adrian
  8. bardissi
    bardissi Member
    Jan 31, 2012
    318
    Happy to hear that the Sonicwall hotfix was the culprit!
  9. RobertKroll
    Nov 16, 2008
    42
    Firmware Version: SonicOS Enhanced 6.2.2.1-14n--HF152075-2n
