v14 Verbose Logging?
Discussion in '3CX Phone System - General' started by TSlocum, Dec 7, 2015.
  1. TSlocum
    TSlocum New Member
    Oct 15, 2013
    225
    15
    I have verbose logging enabled for troubleshooting some issues, but when I go to the Activity Log, there is no verbose option in the filter anymore. It doesn't look like it just shows it by default, because when I enable it on another v12 system, there's a lot more info there.
  2. aberry
    aberry New Member
    Jan 13, 2015
    119
    7
    If you are coming from version 12, they changed the default verbosity, and the location to set it. Now you need to go into custom parameters, and adjust the value there. If I remember correctly, you will need to restart services also.
  3. TSlocum
    TSlocum New Member
    Oct 15, 2013
    225
    15
    You can get to the settings under Activity Log if you click the Logging button on the top next to refresh.
    Anyway, I think restarting the services made it display automatically. Thank you.
  4. aberry
    aberry New Member
    Jan 13, 2015
    119
    7
    Ahh, interesting. Hadn't clicked on logging there. Thanks for the tip.
