V14SP1 - Yealink Firmware Version?
Discussion in '3CX Phone System - General' started by Futureweb, Nov 19, 2015.
  1. Futureweb
    Futureweb New Member
    Jun 29, 2015
    163
    17
    when doing Firmware Upgrade of my Yealink T48G Phones within 3CX - what Firmware Version will it update the Phones to?
    Can't find any information about this?
    Thx
    Andreas Schnederle-Wagner
  2. craigreilly
    craigreilly Well-Known Member
    Feb 1, 2012
    3,586
    309
    Simply clicking a phone and selecting update firmware doesn't upgrade them, but tells you what version it will be updating too as well. Then allows you to continue or backout.
  3. Futureweb
    Jun 29, 2015
    163
    17
    ok - I thought that's the Version my Phone is actually running ... as it's exactly the Version installed on the Phones ... ;-)
    Andreas
