V14SP2 - CDR Time wrong?
Discussion in '3CX Phone System - General' started by Futureweb, Dec 3, 2015.
  1. Futureweb
    Futureweb New Member
    Jun 29, 2015
    163
    17
    using CDR with "Client /Active Socket" configuration - Data is sent to our Logging Software - working fine.
    But the Call Time (time-start_cdr, time-answered_cdr, time-end_cdr) is WRONG ... it's always one Hour behind the actual Time ...
    When a call is made at 12:00:00 - the CDR shows 11:00:00 ... ?
    Time on 3CX Server is showing correct Time, Logging Machine shows correct Time, Phones show correct Time, correct Time everywhere except within CDR?!
    Thx
    Andreas Schnederle-Wagner
