V14SP2 - Weird Conference Calls
Discussion in '3CX Phone System - General' started by Futureweb, Jan 19, 2016.
  1. Futureweb
    Futureweb New Member
    Jun 29, 2015
    163
    14
    sometimes one of our 3CX Android Clients gets Call from Conference Service (9000) when 3CX Android Client is started ... (just happened about the 6th time within the last 2 weeks)
    Happens always on "manual open" of the Client ... on pick up - noone is on the Line ...
    Those Calls also won't show up within CDR or Server Logs??? Because of this I also don't know where those Calls are coming from.
    Any Idea how I can find out what's the cause of those Calls?
    Thx, bye from snowy Austria
    Andreas Schnederle-Wagner
  2. Futureweb
    Jun 29, 2015
    163
    14
    Just searched the "3CXPhoneSystem-20160116-151313.blrec" Log for those Calls - they aren't in there too ...
    Can it be that this call from 9000 is somehow *stuck* within the Android Client?!?
    Don't know what I could do to solve this Problem?!?
  3. Futureweb
    Jun 29, 2015
    163
    14
    I think I just found some information about this with 3CX Log Reader ... Not 100% sure - but according to the Timestamp it could fit ...
    Code:
    18.01.2016 21:48:34:063 | Currently active calls [none]
    18.01.2016 21:48:31:227 | Settings of Extn:7301 has been updated
    18.01.2016 21:48:31:206 | [CM504002]: Endpoint Extn:7301: a contact is unregistered. Contact(s): [sip:7301@127.0.0.1:5488 / 7301]
    18.01.2016 21:48:02:053 | Currently active calls [none]
    18.01.2016 21:47:50:582 | x-call-control DROP: call is not found: Y2MkM2NjZDc8YmI0ZmY5N2ZlNDBkOGYyYWNuN2U2YTT.;from-tag=5b777f6a;to-tag=b42d6874
    18.01.2016 21:47:48:418 | Settings of Extn:7301 has been updated
    18.01.2016 21:47:48:398 | [CM504001]: Endpoint Extn:7301: new contact is registered. Contact(s): [sip:7301@192.168.10.1:50195 / 7301,sip:7301@127.0.0.1:5488 / 7301]
    18.01.2016 21:47:32:041 | Currently active calls [none]
    16.01.2016 23:52:08:880 | Currently active calls [none]
    16.01.2016 23:52:10:771 | x-call-control DROP: call is not found: Y2MkM2NjZDc8YmI0ZmY5N2ZlNDBkOGYyYWNuN2U2YTT.;from-tag=5b777f6a;to-tag=b42d6874
    16.01.2016 23:52:08:680 | Currently active calls [none]
    16.01.2016 23:52:08:342 | Settings of Extn:7301 has been updated
    --> x-call-control DROP: call is not found <-- ???
    same id/from & to Tag on 2 completely different days? What's stuck here?!?
    Andreas
