- Joined
- Sep 23, 2010
- Messages
- 34
- Reaction score
- 1
Help says the following about [ ] Log out from queues checkbox under extension/forwarding:
Am I missing something or is this completely broken?
Thanks!
Tony
- Logout from queues – Automatically logs the user out from queues. IMPORTANT - this will automatically log you out or in from the queue based on a presence change and effectively render the separate Login / Logout button redundant. The status will override this function and log you back in once you set it back to available. Agents must use presence rather than login / logout button if this option is enabled.
Thanks!
Tony
