V15.2.4.122 Connection Problems
Discussion in 'iOS' started by danielt, Mar 2, 2017.
  1. danielt
    Mar 2, 2017
    Device Info
    Phone Model: [iPhone]
    Generation: [7plus]
    Firmware Version: [10.2.1]
    Jailbreak: [NO]
    Cydia Installed: [NO]
    Issue Info
    Handset: [Phone]
    Contacts: [Exchange]
    Connection: [3G/LTE]
    Server: [External]
    I'm new to 3CX, I installed it this weekend. Until now everything is fine as long as I'm connected to my wifi.
    As soon as I switch over to LTE/3G or an external Wifi. I get an Timeout while the 3CX Client on my iPhone tries to register with the 3CX Server at home.
    I'm not sure if this is a problem with my Server Installation or with the Client itself.
    I'm behind a DynIP with a FQDN from 3cx, but i also tried with a static IP from another site which is connected via VPN.
    In both cases the Firewalltest is passed with all green.
    What can i do to debug and hopefully solve this problem?
    Greets Daniel
  2. YiannisH_3CX
    YiannisH_3CX Support Team
    May 10, 2016
    7,402
    535
    Hello @danielt
    Please make sure that tunnel is enabled on the your client and port 5090 is correctly forwarded on your firewall. Also make sure that port 5001 is open as it is used for presence information.
  3. Eric Roberge
    Feb 15, 2017
    I'm currently in the same situation, did you found the solution ?
    IPhone 6Plus with 3CX version 15.2.4.122
    3CX server running version 14
    When i'm on the same network of the server, the 3CX app can connect and works fine.
    When i'm living the office and switching to LTE, the 3CX app stay to "Not registered"
    i can access the phone book, but i'm unable to place a call.
    i run the firewall checker and everything is green !
    Where can i go to find information about troubleshooting this issue ?
    Thanks in advance,
    Eric.
  4. XcamaroX
    Aug 25, 2015
    26
    I can confirm that opening port 5001 to the PBX will allow you to register, as mentioned in the previous reply.
    Good luck.
